Need more info on this part
#534 Tri-flow for AMC V8's replaces all dry sump pickups and allows the pickup tube (in the oil pan) hole to be plugged. Oil can be picked up by means of oil pan sump or other. No tapping of the block is needed (with single line) and this adaptor has provisions for running external coolers, oil filters, oil prelubers or/and oil volume meters or pressure sensors and it replaces entire oil filter adaptor. #534 comes with all holes premarked for easy plumbing.
Check our store for pricing
M.C. I have the Milodon 2 line thru pan pick up, can I use this plate in addition to the Milodon plate? Or can I get rid of the Milodon plate all together and just install this one. I want to add a remote filter but I like the 2 line pick up setup, I like your plate and if it can be used in addition to or in place of (the Milodon plate) it would eliminate the cheesy aftermarket remote adapter. If this will work I'll order one today. Jeff
