Results 1 to 3 of 3
Thread: Tcase to TF727
    Feb 2004
    Green Bay, WI
    170
    Tcase to TF727
    Can anyone tell me what transfer cases came mounted to the tf727 in FSJs? I'm looking at getting one but want to use a part time tcase.
    '97 TJ
    Jan 2003
    s.e. minnesota
    1,348
    I KNOW THEY HAD 208'S, AND THE CASE THE WAG USED 232? NOT SURE ON THAT ONE BUT IT USED A VAC DISCONNECT I THE FRONT AXLE NOT WHAT YOU WANT.
    Oct 2003
    CT
    1,857
    I want to say a D300 will bolt up to it as well. IF the 208 will i think the D300 has the same bolt pattern and spline count
    Paul
    - Mahatma Gandhi
