360 Block/401 Crank - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 360 Block/401 Crank
  1. #11
    Sep 2003
    Oak Harbor, WA 98277
    634
    CR is my big concern I don't want to have to run AVGAS to make this thing run right. Also clearances are a concern... If I can get my hands on a 401 Crank/rods I will do a mock up. I don't want to spend a whole lot on the 401 crank/rods and then not be able to use it or lose money on it selling it. I have some pistons to use.... hell I could even do the clearance checks before I take the motor apart, just put in the 401 crank on 360 rods and do the checks. the pull a few pistons and put the piston on a 401 rod and do the same checks.
  2. #12
    Nov 2003
    Atlanta, GA
    2,386
    MC????? Come on, we know you have this stuff laying around!! Help a brother out!!
  3. #13
    Sep 2003
    634
    Well looking on the AMCFORUM, its possible to make a 360 stroker but custom pistons are a must and if using the 401 Crank/Rods I will have to notch the lower part of the cylinder for clearance.
  4. #14
    Nov 2003
    Atlanta, GA
    2,386
    Shooo, with all that time and money, I'd rather build a twin turbo'd 360. Bet that would be one mean machine!
  5. #15
    Sep 2003
    634
    Yeah that is what I am thinking also...... So I guess back to the original plan of a 360, .040 over, 9.5:1 Compression, edelbrock performer intake, edelbrock 1406 carb, Summit 8600 Cam/timing gears, oiling mods... etc....
    When I have some extra time and money I will do the 360 Stroker...
  6. #16
    Jul 2004
    Through the creek & up the hill
    3
    How about this one?
    I just happen to be working on this very subject and here is what I've come up with so far. Let me know what yenz think.
    -360 block bored 0.040 over
    -401 crank offset ground to 3.80 stroke and 2.00 rod journal size
    -Small journal 5.7" SB che*y rods with wrist pin end honed out to AMC size (0.927 to 1.00)
    -Stock +0.040 360 pistons
    This all adds up to;
    3.8 stroke
    4.12 bore
    9.208 deck height
    5.7 rod length
    1.58 piston compression height
    58cc combustion chamber
    0.045 head gasket thickness
    20cc? piston volume (your size may differ)
    0.028 piston to deck clearance
    9.78 to 1 compression ratio
    405.283ci displacement
    Have I left anything out? Let me know
  7. #17
    Jul 2004
    Route 66 Arizona
    47
    I'm a computer geek by trade in the Navy, so I don't know all the in's & out's of what my machinest is fixin to do, since I'm still learning, but here is what I do know so far (except I can't find my notes...so its all from memory right now).
    - 360 Block
    - Stock heads (ported, will be flow matched @ a later time)
    - 390 Crank
    - 401 pistons (will be shaved)
    - connecting rods (not custom) but form someone like chevy or maybe it was mopar
    - he's also making some changes to the heads, different valves & something else.
    - He's also doing something with the oil plumbing for the rear mains & to help lubing up the distributer gear or something.
    - My machinest has done more than a handfull of the 360 stroker projects with the 390 & 401 crank Using AMC pistons. (as a matter of fact he just completed one...360 block 401 crank SBC aluminum rods & it hauls butt..pistons unknown). Though for some reason he does prefer to use the 390 crank...
    - I'm trying to get permission from him to photograph the process and get the information from him about the complet process (ie what connecting rods, how much has to be shaved, how much grinding etc)
    - Will keep you updated as the process progresses.... droping off the block thursday..... (yes he's already checked the block for thickness & what ever else he checked too). The block wont be done anytime soon though..... Told him I dont need it til around Feb... (Income tax return time)... but I droppin $1800.00 on to get the process started....
  8. #18
    timboamx
    Welcome aboard!
    Good stuff that stroker your going to love it!!
  9. #19
    Jul 2004
    3
    timboamx,
    Hey swabbie!
    Whatcha putin that beast in?
    Hope you trust yer builder like we trust you with our freedom!
    THANKS FOR BEING THERE!
  10. #20
    Jul 2004
    Route 66 Arizona
    47
    I sure do.... He use to race and held a couple of records for the Hornet straight 6 2-bbl.... also he did some work on the "Booth" Gremlin.. His buddy own's it now (right up the road from me apparently)... and he's also lookin it over too. He's been rappin stuff off about AMC and their engines since I met him.
    Tim
