Tranny ID Swap help
Results 1 to 4 of 4
Thread: Tranny ID Swap help
    Oct 2003
    CT
    1,857
    Tranny ID Swap help
    My xj has the BA 10/5 in it currently. According to www.jeeptech.com
    The BA 10/5 is a light duty five speed transmission. It looks similar to the AX-15, but smaller and it is manufactured by Peugeot in France. The input shaft is 1 1/8" 10 spline and the output shaft can be 21 spline or 23 spline.
    My question is: Is there a way to determine what output shaft I have with out pulling the T-case off. I have and extra AX-15 sitting at home and figure I might as well swap that in if My t-case will bolt up to it.
    Also according to Jeep Tech again
    If you own a 21 spline NP231 and you want to swap in a 23 spline transmission, you can either look for a cheap 23 spline NP231 at the junk yard or go to your local Jeep Parts Dealer and order up a new input shaft part #5300-6085. This is the part you need to convert your NP231 to 23 spline input
    How difficult would this be to do as well?
    Paul
    - Mahatma Gandhi
    Oct 2003
    British Columbia
    217
    There’s no for sure way to determine the spline count of your output shaft without pulling the t-case. As a general rule of thumb I have been told the 21 spline was on the 4 cylinder and the 23 spline on a 6 cylinder
    As for the difficulty going from a NP231 21 spline to a 23 spline input, I have no idea. I searched around online, but can't find anything. Asked Tigger, and he said a bunch of stuff that made no sense to me, so he might have some information for you later
    Angel
    The only thing more fun to ride than a jeep is Me
    Sep 2003
    Oak Harbor, WA 98277
    634
    EDITED because I am thinking wrong.
    Paul, 231's are an easy case to work in and on - heck I did it so it must be simple
    When I put the SYE in mine it really was a piece of cake. [new shaft is the bottom one]
    The mongo snap rings were the big problem for me. I broke a pair os snapring pliers - but I got 2 new sets with heavy duty replaceable tips
    It would be easier if you have a press available to remove the needle bearings inside the drive gears - unless your doing the SYE then you throw them away
    I was skeptical about that, but the new shaft is much beefyer (is that a word?) and the gears ride on oil pressure instead of bearings.
