Different Cams run in DD2K
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Different Cams run in DD2K
    Dec 2003
    Colorado Springs, CO
    24
    Getting ready to stuff a cam in my 360, results were pretty interesting, you can tell the low compression is really holding the motor back. If you guys need something run in DD2k let me know, I'll try to get back with you asap.
    The Block:
    '76 AMC 360
    Bore - 4.080"
    Stroke - 3.44"
    Compression - 8.25:1
    Heads - Stock 993 2.02" / 1.625" valves
    Dual Plane Intake
    600 CFM 4 bbl Carb
    Small tube headers with mufflers
    Summit K8600
    HP TQ
    RPM
    2000 132 347
    2500 170 358
    3000 208 364
    3500 249 373
    4000 284 372
    4500 308 359
    Edelbrock Performer 2132
    HP TQ
    RPM
    2000 142 371
    2500 179 376
    3000 217 379
    3500 254 381
    4000 284 372
    4500 300 350
    Crower Baja Beast L2
    HP TQ
    RPM
    2000 142 372
    2500 179 375
    3000 216 378
    3500 253 379
    4000 279 366
    4500 288 336
    HA HA......Mark up another one for the thrifty shopper
    ............. =D>
    Dec 2003
    24
    Here's a couple more:
    Crane HMV-260-2
    HP TQ
    RPM
    2000 140 369
    2500 178 375
    3000 255 383
    3500 287 377
    4000 305 355
    4500 305 320
    Crane Truck Power
    HP TQ
    RPM
    2000 136 358
    2500 173 362
    3000 246 368
    3500 249 373
    4000 269 354
    4500 278 324
    Jan 2004
    Missouri
    153
    Sweet! looks like edlebrock came out pretty good might purchase it. Thanks for the info.
    Dec 2003
    24
    Glad I could help a little bit, like I said before if anyone wants me to run their combo, just give me the info I posted for the block and some cam specs and I'll get back to ya.
    '73 CJ-5 4" Superlift suspension lift, 32x11.5" BFG Mud Terrains,standard issue rusty tub
    '76 360, T-18 trans, Dana 20 t-case
    here is a combo we are building next month for ya'
    401 .030 over
    stock crank rods 9.6 pistons
    502 heads no porting
    R4B intake
    600 cfm carb
    K8601 cam
    headers
    10% under drive pulley
    Dec 2003
    24
    DD2K sez:
    Bulltear 401 .030" Over
    Bore: 4.195"
    Stroke: 3.68"
    Compression: 9.6:1
    AMC 502 Heads Stock 2.025" 1.68" Valves
    600 CFM Carb
    Dual Plane Intake
    Small Tube Headers w/ Mufflers
    Summit K8601 Cam
    RPM HP TQ
    2000 156 408
    2500 198 416
    3000 241 422
    3500 295 433
    4000 348 457
    4500 376 439
    5000 358 376
    5500 348 332
    6000 322 282
    Keep in mind that DD2k can't account for the 10% underdrive pulley, and the R4B's flow characteristics.
    Dec 2003
    24
    Forgot to add....you should strap this motor on a real dyno when you're finished MC and compare the results with the above #'s. I think we'd all be interested to see how far off the two are or if it's pretty much on the money.
    Jan 2003
    1,437
    mine 401 .030" Over
    Bore: 4.195"
    Stroke: 3.68"
    AMC 6090 Heads Stock 2.025" 1.68" Valves
    750 CFM Carb
    Dual Plane Intake - airgap
    large Tube Headers 1-3/4"tube w/ Mufflers
    crower solid 292 cam
    CR 12:1
    RPM HP TQ
    2000 161 423
    2500 210 442
    3000 259 454
    3500 314 472
    4000 365 479
    4500 407 475
    5000 436 458
    5500 442 422
    6000 430 377
    there is nothing for a air gap intake except the dual plane intake
    the flow nimbers are from the a fellow who did a set of heads not mine but a stock set of 6090 heads
    Nice numbers fuzz
    Iluv2xlr8 I pretty much figured it would be around there, With roller rockers and a larger carb we were hoping to hit 430-460 but maybe I will have time to get this one on the dyno
