When I try to engage my four wheel drive with the range lever in my 83 wagoneer the handle moves very easy (it has way too much upward travel). Like it is not connected. The transmission was rebuilt when owned by prior owner. It had rotted vaccum lines so the transfer case was not being used. The previous owner stated that there were no metal shavings when fluid was changed in it after tranny overhaul. I climbed under it and when I tried to move the linkage by hand. it looked like the range lever had way to much paly in it ( when it was moved it did not move the linkage attached to transfer case). I don't think they tried to adjust it when tranny was done due to rotten vaccum lines. I think the range lever linkage needs to be shortened so it has more leverage when pulled up to activate the four wheel drive. My question is how do I do this. There could possibly be one morre problem. Will the transfer case not work if the vaccum accuator motor mounted on it does not move the mode lever. to allow it to go into four wheel drive.
TIA
