power vs manual shaft?
Thread: power vs manual shaft?
    Feb 2004
    Green Bay, WI
    170
    What is the difference between the power steering shaft and the manual steering rack? I'm going to be switching from power to manual and have found they are different part numbers.
    '97 TJ
    Thank you from BT ULTIMUS MAXIMUS STATUS
    Nov 2003
    Atlanta, GA
    2,386
    Give www.flamingriver.com a call and poke at their brains. I believe the shaft length is different and not too sure about the spline count on the box end of the shaft. When I swapped over to power steering, I lucked out and picked up a used box that a shaft already connected to it.
    Jack
