hi guy's , lpg runs great on the 360 v-8's.
facts-1-a larger intake manifold is better ie 4- barrel even small single plane intakes work well!
-2-a straight lpg set up will always work better than a duel fuel but you need good compression 9.5/10 to 1 is good, recurved dizzy colder plugs advanced cam timming.
-3-all basic engine rebuild steps help ie. porting/big valve etc.
-4-free flowing exhaust-single 2.5 or bigger
-5-straight gas (once tuned)will run and start smoother!!
-6-lpg loses out slightly on take off but will rev freely without loosing top end(excepting maybe in a racecar!)
-7-lpg will run hot/cold hill/steep hill/upside down etc..........
i'm running an 83 wagoneer amc 360 hi comp heads impco 425 straight lpg carby fitted to a squrebore holley base plate crane 260h cam advance a couple of deg. B-2 converter re-spun dizzy,b/b chev valves port work,approx 9.5 to 1 comp,4-2-1 extractors,
only down side is you use a little more fuel per mile of lpg than petrol!
and the tanks take up a little more room and you cant carry jerry cans!!
i run 2-tanks @approx. 170 liters and get approx 700km's(435miles)approx.i think!! hope this helps(i no its late!)cheers..d.c.
