there's a large post on ifsja on mufflers, mostly bashing flomaster, i've had those, cheap turbos, and glaspacks, just wondering what opinion's are around here.
I just bought 2 new Turbo II mufflers yesterday b/c i blew one of them up with a back fire a few weeks ago. I have run these for 3 years and have no complaints
I wanted to stick glas packs on but the way i have my tail pipes i would need one shaped like
and can not find them anywhere other than a picture. So if anyone knows where to get them please let me know
-paul
- Mahatma Gandhi
i think walker/thrush used to make them, not sure if they do anymore.
Ive run purple hornies and cherry bombs....glasspacks are cheap and neat....but thats all they actually cavitate your exhaust and you loose a few points of power. Flowmasters are spendy gawdy but flow well...not sure if they flow better or worse than a glassy
I think Flowmasters are over rated. At UTI we had measurable gains with magnaflow mufflers over flowmasters on the dyno. I like the sound of the magnaflows better to. Just my opinion.
'97 TJ
I've got a single 3" Magnaflow on my CJ. Pretty quiet at idle, it has a very nice note at 2500 and above. Being full welded it won't split or rust at the seams, and has taken some good pops on the trail with just a couple of small scrapes.
I have a pretty unique exhaust on my CJ. I have factory cast iron manifolds (free flow). Both sides come out of the manifold with 2 1/4" pipe, the passenger side turns 135 degrees and goes forward, above the driveshaft and under the front of the pan. It turns back on the drivers side, and joins with the drivers side. As soon as they join, they go into 3", thru a high flow cat, the muffler, and out the back in the stock location. The only place that anything is below the bottom of the frame rail is where it dumps at the rear. I got tired of smashing the factory crossover under the trans.
Bob.
That's different. Whatever works.
'97 TJ
Interesting design thought there. I like mine above the lower frame rail too. (but I have a I-6 so it's easy )
Have you had any issues with balancing the exhaust? or valve burn on the short side?
Is your collector still on the drivers side under the clutch linkage (assuming a manual tranny)
So far, no problems. I've had the exhaust on a couple of years with at least one 400+ mile highway drive. The factory Y pipe isn't equal length, this setup just stretches the passenger side a little more. The 2 sides join right below the drivers manifold. The pipe on the DS is only about 8" long and is bent back slightly for flow. The two 2 1/4" pipes are notched together, then welded to the 3".
With my flattened skid pan, and the tight exhaust, the only thing hanging down in the front is the driveshaft and springs, not much I can do about that.
I'm quite happy with the setup, and several fellow wheelers have copied it.
Well imitation is the most sincere form or flattery And I just got back fro UWI for my spring hangers ... they have an old CJ (year couldn't be determined) but it looked like a 304 under the plywood hood - no tranny/transfer. They also have a Cherokee (88?) with a V-8 and auto still in it. When the dudes folks go on vacation this week I'm going to take a day off and play "Lets make a deal" and see what I can get. Right now he only charges me 1/2 what his old man doesOriginally Posted by tufcj
So If can get the motor(s) I may just flatter you too
They also have a 97 TJ for under 5 bills. May need to do some research. My boy will be looking at wheels in a year or so and I can break it er ... I mean ... ah ... break it IN for him
