I'm running YJ (Wrangler) springs on my CJ. The problem is, I still have to use the smaller CJ bushings on the frame end of the shackle. Have you thought of making a replacement bracket to use the YJ diameter bushings on the frame?
Bob.
Bob.
havent thought about that..........hmmm is it the diameter of teh bolt that is different in your bushing or the outside diameter?
I could shave them for a 6pack
The YJ bushing is a lot bigger in diameter, the wide end fits the shackle better. The bolt is the same diameter. The thing is, I bought complete Rancho kits for the YJ (both spring ends and frame), then had to go back and buy a set of CJ frame bushings, so I have several brand new YJ bushings sitting around. I'd just like to see a HD bracket that would accept an un-modified YJ bushing.
