Hey guys been toying with mogs and found a solution to the high center of gravity you will have with these on a coil setup...thats the huge problem with using portals under a jeep frame.
We took coils and made a unloadable coil setup that allows more articulation to the lower side that to the axle moving upwards towards the frame. This is done by utilizing a sliding coil that can actually droop and drop a little to a stop on a steel spud that is welded to the frame and acts as a stop to the coil on top and bottom..Imay be able to take some pics
