Originally Posted by
Toy Maker
Pat, a coule of thoughts.
First, that setup looks like a kidney buster! You should look to loosing some of that shackle (a bunch). Should be abled to salvage several inches. No matter what, you may have to drop the front hangers some. I will try to draw up something you could fab. and e-mail it to you in the next day or so.
Also, the pinion angle can not be set properly until the springs can be loaded to normal ride height as it will change from the no-load condition. After proper pinion angle is determined, the caster angle must be checked and corrected, then you can worry about the steering. 3/8 inch around the bolt on your steering arm is all right, more would be better. However you do it, you should have the hole drilled close then reamed to a snug fit to the bolt you will be using to prevent wallowing in the hole. '75-'79 ford vans E100 & E150 w/PS used a steering arm with about 2" drop. Eng #D5UA-3590-CA. Stock arm will give you about the same 3/8" after reaming.
