anti forward cam bushing (button?)
Results 1 to 8 of 8
Thread: anti forward cam bushing (button?)
    May 2004
    INDIANA
    81
    i saw an anti forward cam bushing (button?) on the AM RACING site #B006 for $34 have you used this and would it be a good idea to use? i assume that it would fit the 8600 cam , and your nickle plated timing cover . any ideas thoughts or suggestions would help, i will be in that area to change the cam gear. since it got chewed up. any one know of this?
    ANTI FORWARD CAM BUSHING
    I HAVE USED THERE BOO6 CAM BUSHING
    IT IS A PLASTIC BUTTON THAT
    YOU INSTALL ON THE CAM BOLT TO KEEP THE CAM FROM WALKING FORWARD
    YOU HAVE TO FILE OR GRIND THE BUTTON TO THE CLEARENCE THAT THEY TELL YOU WITH THE KIT
    THE CLEARENCE WOULD BE FROM THE BUTTON TO THE TIMING COVER.
    MARK
    yeah Brad I am willing to bet the brunt of the problem was that casting flash that didnt allow any oil to the gears
    Oct 2003
    Decatur Texas
    140
    There is no need for a cam button on an AMC that operates and is set up correctly using parts that are built correctly. If you are crashing gears and feel you need a cam button you'd be better off tracing the source of your problem then to apply a bandaid (IMO).
    A correctly ground cam will not walk forward as it's position is retained by:
    1) the correct gear mesh
    2) .001 fwd to rear taper on the cam lobes
    If you are running a roller cam I suppose that is separate issue.
    '65 J200 401
    .002 taper
    Oct 2003
    Decatur Texas
    140
    Smart Asp (thanks)
    '65 J200 401
    Dec 2003
    langley british columbia
    76
    roller cam
    So i take it then that you should use a cam button for all roller cam applications?
    cj7 360 roller motor 291c heads np435 dana300 4-1 plus northwest fab 2.72 black box, currie hi pinion 9 inch front and currie rock jock dana60 rear,38 inch tsls custom shackle reversal and a little bit of rust lol
    yes always roller...band aid for hydralic
