http://community.webshots.com/photo/...58737391lAxBly
http://community.webshots.com/photo/...58737280wUDOXY
http://community.webshots.com/photo/...58737249eWNyDd
Clutch, flywheel, starter, bellhousing, tomken fuel tank, fuel injection lines fuel pump and filter, shackles, and accessories all hung ... alternator which i will replace and the PS pump which im getting a new one. One header is almost on, a warning to those with edelbrock heads get their headers, my doug thorley flanges have clearance issues with the head bolts i have had to grind a substantial amount off of them.
http://community.webshots.com/photo/...58737345ULBSfu
http://community.webshots.com/photo/...58737417uErVdA
I used CJ rear 4.5" RE springs (42 or 43" eye to eye) in the front and rear shackle hangers in front which are a little shorter than normal fronts but are the right width, my dilema will probably be visable int he tie rod picture its looking like the tie rod will hit the steering arm and drag link. so im thinking either mover the rear hanger back a scosh or go to a longer spring (Wrangler RE 4.5 44 or 44.5" eye to eye) and move the rear hanger back accordingly. reason being i cant move the front shackle hanger any further back because of steering box bracket issues and dont want to move the box forward for the same reason as it currently right up aginst the shackle hanger eye. so my only answer is bringing things a little further back with hopes of getting the axle back but without scewing up the shackle geometery.
Any thoughts, granted the tranny and t-case arent in so all the weight isnt on the system yet and that weight could probably help flatten things out a little more.
figured id give you an update after another busy weekend.
