On a CJ you have a gas return line coming off the fuel filter going back to the tank correct, I was talking to someone today & they said that if you remove the return line going to the tank & vent the tank return line to the charcole canister or add a check valve it will help in the performance of the JeeP/carb/engine since the carb will get 100% of the fuel that the fuel pump is delivering to it.
This makes since.
It was also stated that by having the return line you will loose some fuel that the carb may need due to the fact that the filter would be full & some fuel will go back to the tank instead of into the carb.
It was also stated that this was used for fuel savings, hummmmm.
What do you think?
Should I remove the one in Peach's 86'?
The person in question is going to remove his return line & let me know how it made a difference.
RollBar
