Results 1 to 2 of 2
Thread: Leaking Freeze plug Help??
    Bulltear forum member Swabie
    Nov 2003
    Columbia, S.C.
    28
    How do I go about repairing a leaky Freeze plug???? Never seen this happen.
    Its the Last Plug on the driver side.
    Wade
    Wade
    1980 Jeep CJ-7
    T-176
    Dana 300
    AMC 360
    Model 20
    Model 30
    The factory steel ones do occasionally rust through. There's no repair, you need to replace the plug.
    First, drain the block, there's a pipe plug about at the center front/rear, just above the oil pan. These are usually blocked by rust, so you may need to open the hole with a screwdriver after the plug is out. This keeps you from getting drenched with antifreeze in the next step.
    I use a 3/8" extension, and whack the freeze plug on one side (it will take a good whack, get your trusty BFH). They usually will rotate 90 degrees, so half is in the block and half is sticking out. Grab it with a pair of pliers or vise grips and pull it out. Square a new one up, and tap it in. I believe the block uses 1.5" plugs. I prefer to use brass so they don't rust.
    If clearance is an issue, you can get ones that are 2 washers with rubber between that expand when you tighten the nut. I don't recommend them, because eventually the rubber breaks down and the problem comes back.
