Electronic noise...
Results 1 to 9 of 9
Thread: Electronic noise...
    Jun 2004
    Fredericton, NB, Canada
    149
    Electronic noise...
    Ever since my TFI upgrade I notice a great deal of noise in my CB(i.e. engine rpm).. How do you troubleshoot this kind of electric interference or whatever the real name of it is? Is there something to cure this?
    Oct 2003
    CT
    1,857
    I am not sure how to diagnose it. But a lot of times it has to do with a ground, needing an additional one. Or possibly try a noise suppresor.
    There is some info here
    http://www.crutchfieldadvisor.com/IS...car/noise.html
    hope it helps
    -Paul
    - Mahatma Gandhi
    Jun 2004
    149
    it is probably ground related... I had my starter wire short on my exaust manifold.... I'm gonna clean my grounds up and see what happens...
    Jan 2004
    GUAM
    326
    It is called EMI, electromagnetic interference, and yes the most likely cause will be a ground; anything you rewired with your tfi could be suspect, clean and check your connections, the suppressor should be a last resort.
    Hmmm, insert nut and turn....
    http://jeepsr4ever.imgbay.com/charter.jpg
    Jan 2004
    GUAM
    326
    also rust and unlike metals can cause it too.
    Oct 2004
    Rockford, WA
    10
    Re: Electronic noise...
    Quote Originally Posted by FrankNB
    I assume it's RPM related. If that's true I'd start looking at the plug wires, plugs, coil and distributor. Each of these can cause RFI to be eminated...Of course you've boosted the voltage to the plugs using the TFI upgrade. Now you need to contain it... in the wiring and plugs. If you did not change your plug wires then that's where I'd start. A good upgrade to Resistive wiring and resistor plugs may help and the cost is not too bad.
    Jun 2004
    149
    Ok, I'll leave the punch for the end.. but first, I changed my wires for MSD 8mm wires and the plugs are copper plugs.. Grounds are not too bad..
    now here's the punchline... I just noticed that I grounded the CB and the tach together.. That might have something to do with it
    I also think my antenna isn't the best thing in the world.. I like those Firestik, but they're so stiff they keep breaking my stud mounts, and I loose an antenna a year... it gets expensive... so I put a flexible trucker antenna..
    Jun 2004
    Central City, Colorado
    1,626
    Old CB trick.. take your extra antena lead and instead of coiling it or stuffing it gently coil it in the shape of a figure 8 (about a foot long or so, just not too small) then with the last foot or so wrap it around the middle of the 8 like you were storing an extension cord.. wire tie it in the middle to keep it together, this forms a RF choke out of your lead and it will cut down on stray RF interference ( If the ground issue with the tach doesnt clear it up..)
    Dirty Harry.
    Jun 2004
    149
    cool, I got the figure 8, but not the extra coiling.. I will try... thanks..
