We believe that using a planetary gear and a adaptor we can make a stock 304 put out 500ft lbs of torque. This setup would be a underdrive for the engine and would fit between the engine and tranny. Making a tranny to hold up, thats the tricky part
Dirty Harry.
- Mahatma Gandhi
You are thinking way to hard on this one MC K.I.S.S.
Member #377
Here's your tranny and it's a 5speed to boot:
http://mail.telebyte.com/allanw/binder/5speed/
Gonna need a bell housing adaptation as I haven't been able to document one was ever built for the '74 IHC (AMC) 401.
'65 J200 401
That binder tranny is a 2wd type, was used for divorced cases in 4wd applications. I'm not aware of it's output dimensions or if it has ever been adapted to a T-case as a married unit.
Whatch'a think? Check out those gear ratios!
'65 J200 401
The above tranny pics were of the T-34, the one below is of the back of the T-35:
Hmmm, does that look like an NP bolt pattern? Wonder what the dimensions and spline count on the output shaft is?
'65 J200 401
Not an adaptor, that's part of the drive flange for mounting the e-brake.
'65 J200 401
If you are interested in this tranny... I searched a lil more and found someone had built an adaptor to marry a Ford NP205. I wrote to see if I can get a blue print for the plate.
The front input is 1 1/4" x 10 spline, haven't figured out how the bellhousing could be adapted yet... but wrote a couple guys.
'65 J200 401
Ok, AMC 258 & 401s were used in IH rigs, they obviously have the same bell bolt patterns at the engine, IH had a cast iron bell that fit the manual trannies (including the long shaft T1 to the 258... so that would be the bell housing to mate the T34/35/36 5 speed. I know of a place out in OR that rebuilds the trannies if anyone is interested.
'65 J200 401
