Has anybody done or attempted this?
I have all the parts sitting here on the floor and it will bolt togather,but there are a couple issues.
First of all is the flexplate,you cant use a TH400(only has 3 mounting bolts) nor can you use a 727 flexplate.The AW4 TC has 4 mounting tabs but they are 9" apart where the 727 plates holes are 10" apart.You could use the AW4 flexplate,but would it need to be rebalanced?
Next issue,the pilot bushing.I'll just have to figure this one out unless someone has already done it.I have several V8's and a couple 6's to check to get ideas.
Next comes the starter.The AW4 and the V8 starters nose cone are diffrent and the throw of the bendix is diffrent.
TIA in advance for any guidance,
OlyWa
