Well you know on a stock CJ how the oil from the rear port/hole in the valve cover gets sucked up into the air cleaner & the filter gets full of oil after a while...........try this,
Take the small plastic 90* bend off & go match it up @ your local AZ or Parts store & replace the plastic 90* w/a PCV valve, it keeps the oil out of the filter/carb & you will get better fuel mileage & won't have to change the filter as much.
Just a thought,
RollBar, aka. Street2Mud
