transfer case id
Results 1 to 2 of 2
Thread: transfer case id
    Jan 2005
    georgia
    7
    transfer case id
    i have been to all the jeep forums, a lot of websites and i still cant figure out what i have. 80 cj7 on title vin says 79, numbers on case say c33-15-2. there are 2 little tags coming off the bolt next to the housing that i cant read. front housing aluminum on passenger side rear housing cast iron with speedo on drivers side of housing any body have any answers as always thanks for the help.
    Dana 300's have a round bolt pattern to the transmission. Dana 20's have a weird texas shaped pattern. Also for its year could be a dana300 short shaft rear. Does the yoke come right out of the back or is it out of a aluminum housing out the back...in either case the dana 20 has a cast iron housing out the back. You could find a dana 20 in a 80' or a dana 300.
