Results 1 to 3 of 3
Thread: rear dana 44
    rear dana 44
    I am looking for a 44 to build up. It is going on to a tj so everything will be cut off. It needs to be ATLEAST 61 wms to wms. As far as the carrier I would prefer one for a 4.88. If you have any lockers or other parts that may be usefull in my build up let me know.
    Oct 2004
    RICE, MN
    123
    I have a dana 60 semi floater 5 x 5 1/2 from a J-truck with a cracked tube by the spring pad with 4.10 gears. Don't know the WMF to WMF.
    Apr 2005
    Clinton, NY
    7
    Not sure if this is what you're asking for, but I have a passenger drop NT Dana 44 rear axle from a '79 Wagoneer LTD. Dunno what WMS is, but there's pver 52" from between the inside of the backing plates. The ring/pinion is a stock 3.07 ratio. Located in Clinton, NY
