Well, I finally have my set of scout dana 44's. I'm getting ready to piece together my parts, and I have a question. Is the front ring&pinion reverse rotation or standard? Will the gears and carrier interchange with the rear end? Thanks guys.
79 (mostly) CJ 7 304, T-18, D300 D44s, Spring over lift on 35s
Front is standard rotation, and ring/pinion & carrier will interchange with the rear. Front/rear swap of gears requires set up from scratch, it's more than a bolt in.
