Is my oil pressure within spec?
Results 1 to 6 of 6
Thread: Is my oil pressure within spec?
    Mar 2005
    Atlanta
    8
    60 psi at startup.
    40 psi cruising at interstate speed.
    13 psi hot idle
    AMC 360 with 10K on remanufactured engine.
    I am currently running Mobil 10W-40
    My 1979 TSM says I meet the minimums but as we all know that does not usually equal a long lasting engine for the AMC 360's.
    My goal is to get more than 80K on this engine this time around.
    Thanks.
    79 Wagoneer Limited
    Sounds a little low hot...probly due to pump scoring
    Mar 2005
    Atlanta
    8
    What would you recommend as a fix to get the oil pressure up a bit?
    Greg
    79 Wagoneer Limited
    If it were me this is what I would do in this order
    1. New oil filter
    2. thinner gasket and new gears
    3. midplate
    4. new oil filter adaptor
    5. new timing cover
    Mar 2005
    Atlanta
    8
    Ok thanks for the tip.
    I will try the new filter and will probably go with the new pump gears.
    Is that a difficult install?
    I need to look at my TSM.
    79 Wagoneer Limited
    Nov 2003
    Atlanta, GA
    2,386
    Sounds like a good beginning. If those don't work - like MC said, try the thinner gasket and midplate, and if that doesn't work, then get a new timing cover. You'll track it down eventually!!!
    Jack
