Hello
Results 1 to 7 of 7
Thread: Hello
    Hello
    New to this, so here we go.
    I have a stock '86 jeep with
    4.2/999 auto/ Dana 300/Dana 30/Dana 44
    Want to swap to 727 torqueflite
    Will it bolt up without major mods?
    Will I have to modify drive shaft?
    Oct 2004
    RICE, MN
    123
    Why? The 999 hes a lower 1st gear than the 727(2.74 vs 2.48 I think)
    and it's shorter too.
    You can swap it but you will need to run some lift in front as part of the pan will hit the front driveshaft....unless you have a clockingplate
    Jan 2004
    apple valley ca
    3,435
    keep the 999. changing your current setup might not be worth the hassle.
    anyways welcome aboard =D>
    83 eagle (r.i.p.)
    85 gl1200 gold wing LTD pilot
    corrupting people since 1962
    Thanks for the reply's, I have a spare 999 at the rebuilders now, should be ready this week. I was told that the 904 is the same except lower first gear. Is this good info?
    I do believe it depends on what it came from.. Didnt the 904 with the AMC bellhousing share the same first gear with the 999's?
