How hard is it to put a 401 from a J20 into a CJ7 frame? Is this block the same as a 304?
Nothing is fool proof to a sufficiently tallented fool!
Can you change a lightbulb
Yup, it will bolt right up. Just make sure that you have the right flexplate/flywheel to balance the AMC 401 - the 304 one will not work. Other than that, it is a direct swap!! Let us know if you need more help!!
Jack
Cool! I found a 74 J20 for 250$. Body is gone but I don't need that. Will have to rebuild the 401 tho. Now to figure out what mods to do to the engine.
Lucky f#cker!!!Originally Posted by grignac48
Well picked it up. Not bad. Set for 6 years. Has headers on it with motorcraft 2 barrel carb. Custom dual tanks. Because original rusted out Anyone need parts for a j20?
Defintely a complete rebuild. I am on my way. Hope to get the repaired frame back this comming week and put the lockers in and I am ready to start the engine. =D>
Are you sure it's a 401? Did you look under the motor mount (displacement is cast into the side of the block)? There should also be a metal tag on the front of the right valve cover with the letter "Z" on it, and the 7th digit of the vin should be "Z".
The reason I ask is that all 401s came from the factory with 4BBL carbs. Not to say a 2BBL couldn't have been swapped on, but it's just a question that needs more investigation.
Is that like the little metal tag on the axle that doesn't last ??Originally Posted by tufcj
hehehehe Pat
Yes, but they also cast in the engine size. Sould say on the block, 401, 360, 304.Originally Posted by Mudrat
Pics of Jeeps
Good point I will have to check it out tonight. I just took the guys word for it. Plus it was a good buy either way. Here is a pic of the top end.
http://pg.photos.yahoo.com/ph/rammin48/album?.dir=/2241
