I just started mine - - - - againOriginally Posted by grignac48
OK, so I've gotten Erin's YJ 'bout done and over to the inspection station (yea Virginia ) Just need to install the tune machine and speakers.
So I figure it's time for me to get back to fix'n my rear brakes in the CJ.
I stuffed a late 80's HD-AMC20 axle under there with a 4.56 Detroit replacing the stock one with an open 3.73.
The plan is to strip all the BS off it - old shock mounts, the bent Chebby chit the PO had installed (tired of bending and tweaking trying to get the brake pads set up right, and maybe the original perches??
I cheezed out and bought a whole setup from TSMMFG
Got the axle out and up on the work bench - a task when one is by one's self! I aint big enough to clean and jerk this thing soooo .... with a 2 ton chainfall and a dog chain - got'r up there
And of course the obligatory cheez shot with my likeness :P
So I unbolted and pulled the axle shafts, stuffed rags in the ends and figured now is the time to replace the seals and bearings too. But what did I find??? Spun splines on the long side :twisted:
So instead of just changing the bearings, I'll be changing the shafts too. And probably jerking the diff to inspect the splines in there too :twisted: :twisted:
Stand by for more as this project progresses ...
Pat
