2-row radiator question
Thread: 2-row radiator question
    hello.What is the possibility of me using my 2 row cj7 6 cyl. radiator on the amc v8 360 I installed?The engine is running fine and I have only been running the engine in neutral.The temp gauge is hooked up and it seems to be staying in operational temp.However I do have the front clip off.I do not want to reassemble the jeep and then once I'm driving it have an over heating problem due to the 2 row radiator.I was just wondering if anybody else has ran a 360 with the 2 row radiator.
    I did successfully with a high flow water pump and a fan shroud for 2 years in a cj7 offroading hard
