Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2962 291C heads question
When replacing the original heads on an 89 360 with some 291C heads can I use the original pushrods/lifters? Have not changed the camshaft yet. Looking for some advice from the AMC gurus out there.
Lifters, yes, if you are not changing the camshaft. Push rods are iffy. Depends on if the heads have been surfaced, head gasket thickness, etc. Best take some time to check the rocker arm geometry with stock push rods. Better yet, an adjustable push rod will help you determine the length of push rod you need to have correct geometry.
