what type of rear end?
Results 1 to 10 of 13
Thread: what type of rear end?
    what kind of rear end came in a 70 sst 390 from the factory? It is the stock housing just modified internally, 5.00 gear and a locker, but i guess the locker could be factory, not sure here.
    Should be an AMC 20. Perfectly round cover with 12 bolts.
    thanks, I was just wondering how hard gears are going to be to find for it.
    I want to change it to a 4.10 or something in that range.
    Most everyone has gears for them. Same center section that was used in Jeep CJs until 1986. You can get gears at Jeep sites all the way up to 4.88. I went with 3.73s in my 69 AMX (390/auto, 3.15 gears stock). With 26" tires and those gears I'll be at nearly 3500 RPMs at 75 MPH. I didn't want to rev it higher than that if I take it on the highway. Kind of a compromise between off-the-line power and highway revs.
    Sep 2005
    Seattle Area
    25
    You know you could toss in a 5 speed and fix that high rev cruise.....
    Thank you from BT Ultra tech
    Jan 2004
    Michiana
    457
    What 5-speed might that be??
    The T-5 is not up to the amount of power that can be made by a good running AMC V8. The Rebel Machine had a 390 with a cast-iron version of the R4B and was rated at 430 ft/lbs. of torque. A modded 390/401 can go to 500/500 quite easily. Add traction to that equation and you have a problem.
    Richmond no longer sells 5 or 6 speeds for AMC. If you find me one, I have a $100 bill for your effort.
    The AMC20 will make a long streak of 90wt for the tow truck to follow.
    An early (65~72, 65 style being a little narrower at the flanges) Mustang nine-inch is practically a drop-in, very little changes. Bigger U bolts, shock mounts to fit the bigger U bolts, & an adapter U joint. Piece-O-cake.
    If you are wanting to sell the locker & gear, it may be the rare Group19 goodies and worth a fair chunk of change, enough to cover the upgrade to the Ford 9" with whatever gears you want, traction bars, plus a posi for it.
    Jan 2004
    Michiana
    457
    Check out the '70 Javelin T/A pic in this thread:
    http://www.bulltear.com/forums/viewt...?p=32543#32543
    Jul 2005
    S.W. WA
    692
    Quote Originally Posted by Holeshot
    Boy, I shore hope the T-5 I'm putting in my Rebel holds up at least for awhile.
    BTW, won't a Chevy manual trans work? I know it will bolt to the bell housing, and the input shaft is 1-1/8" 10 spline, but I don't know about the pilot lenght.
    1969 Rebel 401 TH400
    1978 J10 401, QT
    1978 Wag 401 QT
    1973 Javelin AMX in pieces.
    Jan 2004
    Michiana
    457
    I'm slowly getting some tranny data edited & uploaded to my website....
    The discontinued Richmond "Street-Five" for AMC...
    The crank on the left is early, right is '72+...
    AMC manual trans table...
    http://www.american-powersports.com/...nual_trans.htm
    TONS of trans info, including AMC/Jeep:
    http://www.american-powersports.com/...s/am_trans.htm
    Common tranny ratios...
    http://www.american-powersports.com/...ans_ratios.htm
    Adapt a Ford trans to AMC...
    http://www.american-powersports.com/...ford_to_am.htm
    Flywheels...
    http://www.american-powersports.com/..._flywheels.htm
    Here's the base URL for trannies...you can navigate it like an FTP site:
    http://www.american-powersports.com/amc/tech/trans/
    Jul 2005
    S.W. WA
    692
    Ahh..
    1978 J10 401, QT
    1978 Wag 401 QT
