Crankshafts, we need crankshafts
Results 1 to 10 of 10
Thread: Crankshafts, we need crankshafts
    Jul 2005
    S.W. WA
    692
    The #1 part for the AMC V-8 that seems to be missing from the aftermarket is a good quality, yet affordable crankshaft (I love that word ) Callies will custom make one for about $2200, but it would be nice to just buy one off the shelf for about 1/4 that price. Yes?
    1969 Rebel 401 TH400
    1978 J10 401, QT
    1978 Wag 401 QT
    1973 Javelin AMX in pieces.
    Jun 2005
    Sunbright,TN
    42
    I'll be needing a crank shortly myself, and I'd rather not have to use the stocker in my 360.
    Jul 2005
    S.W. WA
    692
    Yeah, and I don't know of anyone selling an AMC crankshaft for under $2000.
    1978 J10 401, QT
    1978 Wag 401 QT
    Thank you from BT Ultra tech
    Jan 2004
    Michiana
    457
    Cranks?
    Hi....I've been using AMC engines for over 25 years now, and have never destroyed a crank. Have to have one turned every 20 years or so, though. You guys been using those off-brand boat anchors too long.
    Useable 401 cranks go for around $200 on Ebay, what more do you want???
    On another note, Speed-O-Motive will offset grind (428 cubes, 434 with + .030" overbore(as I recall)), fillet radius, nitride, cross-drill, & lighten YOUR 390/401 crank for about $1000. Sad thing is, you will actually LOSE horsepower (according to Dyno 2000) as you increase stroke, but you can gain a whole 20 or 30 ft/lbs of torque. Whooopeee!!!!!
    Nostalgia ProStock.
    Jul 2005
    S.W. WA
    692
    The main problem I see with using a stock crank, even one that has had the full treatment, is that it is between 14 and 40 years old, and has been flexed a few million time already. Anything metal has a finite fatigue life, and I would hate to start a race motor project with a crankshaft whose life might already be more than half over. I'm not talking drag racing, but sustained high rpm (over 7500) operation.
    1978 J10 401, QT
    1978 Wag 401 QT
    Jun 2005
    Sunbright,TN
    42
    So, it is possible to use a 401 crank in a 360? If so what all has to be done ? I would consider it, if it's not to much trouble.
    Jan 2004
    Michiana
    457
    Crankshafts?
    Flexed???? Have you ever seen a 401 crank??? I hardly think there would be ANY flex, and metal fatigue would not even be a consideration. If it passes all the pre-machining tests, it's a go. I've NEVER heard of a 390/401 crank breaking, though I suppose there must have been one.
    If you are building an engine to make over 1000 HP and last a while, cost better not be a concern, and maybe you had better use an aftermarket crank anyway.
    Nostalgia ProStock.
    Jan 2004
    Michiana
    457
    Cranks?
    ...in addition, if you are getting a crank out of a run of the mill 401 Jeep, it has probably never seen 5500 RPM and has lived its life with a very low compression ratio, never coming close to stressing the crank & rods.
    Here's the specs I got for offset ginding a 401 crank:
    Magnaflux, offset grind 401 crank to SBC SJ 2.0" (3.93" stroke), 1/8" filet radius, nitrate, nitride, knife edge, lighten, internal balance $1,050 at Speed-O-Motive
    As far as using a 401 crank in a 360 block, all of the AMC blocks (68 & up) have the same main journal size and bore spacing, so I don't know why a 401 crank would not fit. But I think the 401 block has thicker webbing, making it stronger. I never considered using a 360 block since 401s can be had at a fair price.
    Nostalgia ProStock.
    Jul 2005
    S.W. WA
    692
    Don't take my word for it, ask some of the other guys on the forum, ALL crankshafts do flex, granted, it is a very small amount, but it is flex. As far a breakage, there are plenty of sob stories over on the AMC forum from pretty experienced builders breaking their motors.
    Point is: the 401 well WILL dry up, and much sooner than any of us would like, and I for one would like options other than $2300 custom billet cranks and $4200 ICH blocks, wouldn't you agree?
    1978 J10 401, QT
    1978 Wag 401 QT
