bellhousing
Not a motor to trans adapter, but an actual bellhousing where you cut/grind off the original (IE: 700R4 or 45RFE to put an AMC 360 in a Grand Cherokee. <G>) and bolt up an AMC motor.
They make them for racing, but not AMC motors ("not enough call for them", as if they even noted how many calls they got!)
Here's what I mean: http://www.racewithjw.com/JW_catalog.pdf
They make them for TH350 and TH400 to AMC (too much internal drag and no overdrive), but not 727 (which would also work with an A518 O/D and maybe 45RFE)
- You may not post replies
- You may not edit your posts
Forum Rules
