The flat spot your speaking of could be from many things. What size of carb? what intake manifold? what lobe seperation on the cam? How much compression? What kind of tranny (and stall)? What does your engine have for manifold vacuum? Is your idle set correctly? What kind of timing are you running?
In the several instances I've seen rhodes used in small block fords, small block chevys, and big block chevys there has been no problems. I have no idea about the claim of them being made in the USA, but that wouldn't be as important to me as how it would effect the valvetrain.
The cam timing is most likely something that should be messed with, you need to address the individuality of ANY and EVERY combination, it is just a tuning tool that can help decide what kind of tune you prefer.
