External Oil Pump Brackets
I have a few ideas so I will post them in seperate topics, What about a mounting kit that a guy could buy and install a Moroso 22596 pump on a AMC engine. Would be a easy way to get a trick oiling system and eliminate the aluminum timing cover pump.
Thank you from BT
Tech Master Bulltear Forum
you might also be able to use an external pump and a filter relocation kit to get a belt driven pump and bypass the internal pump
That is exactly what the plan is but it would be nice to buy some off the shelf nice billet aluminum machined brackets to bolt the pump to the engine in the proper location. Just easier, thats all.
- You may not post replies
- You may not edit your posts
Forum Rules
