Sounds like it's comeing along. i've had a merry-go-round of a ride with my 401 swap. almost everything needed replaced, cant believe it ran as good as it did after the rebuild, but between swapping out the distributor, replaceing the ps pump and fabbing a new bracket, makeing a newer style alternator work with my 7/16 bolt pattern, rebuilding my York compressor, extracting a few broken bolts (except for one that had to be drilled and tapped), locateing a carb, motor mounts, brackets, pulleys, waiting on parts, and looking for lost tools.....its comeing along. Now to deal with my cracked exh manifold problem and i'll be able to route fuel lines and hook up the electrical. Bright side is the Edelbrock intake looks nice on top of that pig.
Sorry to semi-hijack, glad your project is rolling along
