Hey everyone - I used my old dizzy and shaft (which is true as far as I can tell by rolling it) to install in the engine, ready for priming. When I turn it by hand, it turns very smoothly but gives a bit of resistance every turn - it doesn't feel like it's binding, and I can't remember if my old "new" pump did this as well. I am not using the super thin gasket. Also, it seems like the shaft is trying to raise up just a hair when the resistance starts. After noticing this, I loosened the bolts for the adapter plate, but that made no change.
So, my questions are:
Is this normal?
and
Is this why distributor shafts have a slight amount of play up and down within the distributor housing?
Thanks for any input! :)
