oil pressure question
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: oil pressure question
    May 2005
    Quito, Ecuador
    52
    Hi,
    I don't know if this is normal or not but I'll ask...
    I just noticed that the oil pressure on my 360 when I start it cold takes about 1 - 2 seconds to build up. Is this OK?? Previously, I had only noticed a delay in the pressure build-up when I changed the oil.
    After the first start-up, I think it's fine. If I turn it off and and on again, the oil pressure gauge goes right up to normal ~50psi.
    Thanks for any response.
    - Pablo
    1981 CJ-7 Laredo 360 V8 - Edelbrock EFI & Heads
    1995 YJ Sahara
    Pable sounds like you are using a filter without a anti drainback provision. I would suggest a different filter first
    Jun 2005
    Chandler Az.
    18
    I experience the same problem with three second delays before oil pressure is present during start-up.
    The Fram, Napa and the CARQUEST Premium BLUE oil filters all have Anti-pass back. There are others.
    Have you found one filter better or worst than others?
    Would you recommend a good oil filter for AMC V8 motors?
    Wix, napa gold are the filters I recommend. They are both made by Dana corp.
    Feb 2005
    East Bethel Mn
    1,260
    what about dana going bankrupt, are they still going to be doing buisness when this is all said and done
    VOTEBUTTON
    Dana just wanted to get out of paying bills. Depending on which chapter they went with someone got hooched out of alot of money. Thats big business
    OK, the latest on Dana's Chapter 11 is HERE
    But MC, I've been looking at your sig line pics, Jeeps yes - but what the heck is this?? A head mill??
    May 2005
    Quito, Ecuador
    52
    Just came back from installing a FRAM PH-25. Seems to be fine now... Although my friend's 258-powered-oil-gauge seems to be quicker to go to the middle.
    Thanks a lot for the responses.
    on a sidenote, jeepsr4ever, what are the benfits of the oil pump kit you sell?
    - Pablo
    1995 YJ Sahara
    I have heard from many people that the PH25 is the incorrect filter to use for our trucks - the PH11 is better because it is much larger and can filter more effectively. I have also heard that Fram got the part numbers wrong...
    1974 Jeep Cherokee S, 401
    See home page for specs
    Quote Originally Posted by pablorg
    Pablo steer clear of the Frams if possible. The Wix is a better choice and will offer less load on the distributor/cam gears.
    As far as our pump are concerned they come with tighter specs than the factory pump and have been outlasting the factory pump because of this.
