401 Cam Question - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 401 Cam Question
  1. #11
    Quote Originally Posted by Dusty
    just out of curriosity why are you re-using oversized pistons from another motor??? are they Cast pistons to boot? dont waste your time if thats the case, you are spending the money for good machinework why risk putting pistons that already have wear patterns for another block into a freshly bored motor.
    What compression ratio are you hoping to end up with. 9.8:1 will run on pump gas no problem.
    dont bother with the stock cam spec. they ran the same cam in 304, 360 and 401 that will give you an idea how choked your motor was. the .479 lift howards cam is a mild RV style cam similar to the stockr but with better duration #'s and lift stock was close to .450
    The 401 had a different cam than the 304/360. According to the FSM for my 77 Cherokee, the cam specs are:
    304/360 cam:
    Cam lobe lift: 0.286 inch (with 1.6:1 rocker, you get 0.4576 inch)
    Intake valve timing: open: 14.75* BTDC; close: 68.75* or ABDC
    Exhaust valve timing: open: 56.75* BBDC; close 26.75* ATDC
    Valve overlap: 41.50*
    Intake duration: 263.50*
    Exhaust duration: 263.50*
    401 cam:
    Intake valve timing: open: 25.57* BTDC; close: 90.75* ABDC
    Exhaust valve timing: open: 80.80* BBDC; close 42.75* ATDC
    Valve overlap: 68.32*
    Intake duration: 296.32*
    Exhaust duration: 303.55*
    You can see that there's just a little bit of difference between the two cams...
    1977 AMC Jeep Cherokee: 360/TH400/1339/44/44 - Beavis
    1984 AMC Jeep CJ7: 401/SM465/AtlasII/44/9" - Grimm Jeeper
    1986 Chevy K20: 5.3/4L60/NP241/10b/14b - Tow Rig
    2004 Pontiac GTO: LS1/T56/M80 - :D
    Try out my gear ratio calculator (Now in metric)
  2. #12
    Missoula MT, Now in Santa Rosa Ca
    759
    my bad wasnt stock lobe seperation 115 or something like that also
    Member #377
  3. #13
    Jan 2005
    Middletown, PA
    590
    After talking with the machine man we decided on new pistons, most likely Speed Pro forged, and Comp Cams Magnum 270 cam kit. Now to find the cheapest prices, leaning toward ebay??????
