AXLE MOVEMENT
Results 1 to 2 of 2
Thread: AXLE MOVEMENT
    Oct 2003
    modesto, ca
    62
    AXLE MOVEMENT
    79 CJ7 401, RE 6IN LIFT & 35S. THE PROBLEM IS WHEN I EXCELERATE OR SHIFT SOMETIMES IT FEELS LIKE THE REAR AXLE IS SHIFTING. I CHECKED ALL BUSHINGS. BOLTS, CENTER PIN AND NOTHING WRONG. I'M THINKING POSSIBLY SPRING WRAP ????
    2007 durango
    79 cj7 401 t-18 488 s lockers both ends 35 s
    97 F350 crewcab 4x4 power stroke banks equipped. just added the exh. brake. I LUV MY TRUCK
    94 WRANGLER
    90 WRANGLER BASKET CASE
    Most likely spring wrap. Some will take a bar from the top of the axle or pumpking and attach it with heims and run it to the cross area in the back part of the body or run a cross member.
