Enough beef for 401?
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Enough beef for 401?
    I'm a drivetrain novice. I bought a cj5 with a 401. There's no gears in the front differential. I think the guy punched it and broke some teeth off a ring gear or something. It's got a Dana 44 rear. Not sure what the ratio is yet. I've got a Dana 30/AMC 20 combo from my other CJ. My question is what would be a solid front rear combo to handle the 401. I'm not heavy footed, but I also don't want to be off in the woods and bust a gear. Price is an issue, but I'm not scared to spend either. Trying to make a list of things I want. Not sure what models the tranny/transfer case are but it's a 3 speed and the TC is 4H-2H-N-4L
    What size tires you gonna run?
    Moderate or extreme riding?
    I would dump the 3 speed and probably go with a T-18 4 speed (or something equal) especially if you are mainly doing woods and not road.
    D-44's are OK for moderate.... but not extreme. D-60, 14 bolt, D-70, for extreme. Rockwell's handles very extreme trails and are still fairly cheap too but are going up in price. Mogs are great but on the expensive side.
    A CJ5 is a lot of fun....and exciting to wheel in! Good luck to ya!
    IF FIRST YOU DON'T SUCCEED...THEN MOPEDAL!
    Quote Originally Posted by MoPedal
    Good questions ... the size of the tire will control engine RPM. You wanna stay in the power band when you are doing whatever kind of wheeling your going to do. Example - on road your engine will need to be runing in an economical range at 60-70MPH - off road, low-range shoud be in the same RPM range, the problem is that may put you too fast for the tire size (31's vs 44's ) so let us know what it is you want to do and we can be of some more help.
    And I want to see a 5 on MOGS!!!!! THAT would be something Been thinking about them for the 7
    'Rat
    I ran a Dana44 rear, Dana30 front with 35s. I broke the front carrier once, and broke a handfull of front axles. I twisted the axle splines on the 44, but never broke a shaft. This is doing some fairly difficult rock crawling with a power-lock in the front and a Detroit in the rear.
    I'm currently running 44s in both ends with detroit lockers and 37s. I have a 60 fo the rear to be built some day.
    Gear ratios 4.10-4.56 with 33s, 4.56-4.88 with 35s and up. Keep the 44 rear and you might even go 5.13 if you're above 35s.
    I currently have 4.27s with my 37s, and it's not quite enough gear (street or trail). I have 4.88s waiting to go in (with the 60).
    Quote Originally Posted by mudrat
    'Rat
    Mogs on a 5 would be a sight. Wow what clearance!
    I ran a Dana44 rear, Dana30 front with 35s. I broke the front carrier once, and broke a handfull of front axles. Was it the axles that broke or the u-joints coming apart? Most of the breakage on my front 44's was u-joints
    The rear shafts will twist up to 25* or maybe more....I have always been amaised how far they will twist without breaking! But I wasn't as lucky as you...I've broke a few!!
    How do they like those 37's??...seems like once you get over 33's they start "crackin" (depending on the trails)
    I think you'll really like the 4.88's and the pinion still has some meat left on it too!
    I can almost guarantee you I'll never run anything bigger than 36's, and most probably I'll stick with 33's. Those unimog axles look stout, but i read somewhere a pair weighs like 1200 pounds. I don't want anything that heavy. I won't be doing any rock climbing. Just backwoods swamp riding and some in the river sand. From time to time the mudholes get deep in the swamp and I don't want to gouge it and break something in a hole. Not looking for bulletproof, I just want to be able to hit the gas without stuff flying apart.
    759
    4.88's with 35's in direct with a .512/.525 lift 228/234 dur @.050 112 lobe sep cam from crower on a 9.8:1 401 .030 with a T-18 in a CJ7 the combo works great little lobety lope but not enough to cause any issues Performer intake is a little small but keeps up port velocity on the bottom end. Probably going to a Airgap when i get time. 770 for the carb. the 4.88's are ideal for up to 70 mph knocking on a little high on the rpm range but thats at 70 mph everything else is on the dot for good to go.
    I ran a scout 44 rear for a long time no issues with q powerlok front and rear now i have a 60 with p-lok and 4.88's. the 44 twisted some but never broke in 5 years oif wheeling
    Member #377
    Nov 2004
    Aggieland
    85
    Sounds like you need a pair of scout or wagoneer axles. Use 15x8 wheels with 5.25" of backspacing if you don't want the tires to stick out very far. They'll stand up pretty good if you're reasonable on the throttle offroad.
    I run 4.10 gears with 38s and would never want lower. That gives it a good cruise rpm at 60mph. Unbalanced worn swampers shake too much above 60. And I only have a 360.
    For offroad slow going, I have a np435 and a dana 300 which is about 3 times slower than your 3 speed and dana 20. A t-18 is almost as low and fits better. Put one of those in, and swap in a dana 300 transfer case while you're at it. The dana 300 has lower gears than your dana 20 and 4:1 kits are affordable if you want lower.
    81 CJ8 on fullwidths with TBI 360 and some other stuff.
    Texas A&M Off-Road
    Jan 2005
    Middletown, PA
    590
    Good luck. These 401's make a LOT of torque! Here's what ours did to a full float Dana 60 rear axle the day after we got the 401 in.
