alright i want to double check that i understand this all first
My goal is to have an engine to produce 300+ ft/lbs at 200 rpm and still be able to produce good high hp numbers at 5-5500 rpm(350-400) from what i understand 87 ocante is capable of an effective compression ratio of 7.5:1, if this is correct and the effective CR calculator says that i would need intake valve close time of 43d after bottom dead center or later(as close as possible in order to maintain as much fuel economy as possible because compression is important for that...not going for honda just want to be able to afford to drive it)
if my understanding is correct iused desktop dyno2k to create a cam that is able to produce 400ftlbs of torque form 2-5k and 380hp(.49 lift, 218 intake, 247 exhaust, 116 degrees seperation)is my understanding correct? are the numbers correct (7.5:1 on 87?)
