No oil pressure after sitting overnight in cold
Results 1 to 5 of 5
Thread: No oil pressure after sitting overnight in cold
    Mar 2004
    Jackson, MI
    9
    Can't quite figure this out. I drove the Jeep yesterday (2+ year old rebuilt 360 with , new timing cover, new pump and plunger spring ~9K on all of it) Oil pressure was 30-35 at 60-75 mph and dropped down to 10-20 at idle. Parked it last night, woke up this morning and started it with no oil pressure. Let it run for a couple of minutes and still no pressure on electric gauge. It did this last year, but I changed the filter, oil, plunger & spring and op sender and it seemed to solve it last year (or it got warmer I don't remember) Any ideas? Is something getting in the oil to sludge it up or freeze it? It is 10w-30 Mobil 1.
    Also, my hot oil pressure keeps dropping. Does that mean worn rod bearings?
    Thanks in advance...I think
    Sep 2006
    Stamford, CT.
    125
    First I would dump the electric oil gauge and get a good mechanical one.
    I would worry with 30-35 psi @ 60-75 mph then again your reading from a not so good gauge.
    You said you “Let it run for a couple of minutes and still no pressure on electric gauge.” Did you hear lifter noise or heavy knocking? If not it may be the gauge.
    Sludge with Mobil 1 I though it was to stop that? And if some thing got in the oil pull dip stick and look. I say do the first line and get back to us.
    Dave ----
    75 GremlinX v8 64k
    76 GremlinX i6 (15yr sons)
    70 Javelin MD 390/4sp (360 now)
    70 Javelin 1/4 Drag car 360/auto best time 12.88...best speed 103.64 mph...best 60' 1.835 no tuning
    Check to see if the wire fell off the sending unit.
    Mar 2004
    Jackson, MI
    9
    Wire is still on the sender - good connection there. Oil topped off and looked fine yesterday. There is some lifter noise (also a exhaust leak) and possibly a knock, but my flexplate is also due to be changed I believe too. I didn't have much time to check this morning before work.
    I am going to put a tee in and run a mechanical gauge this weekend.
    Nov 2005
    Middle of the Iron Range MN
    1,229
    pressure bypass might have stuck open causing no pressure
