Results 1 to 5 of 5
Thread: hydraulic winch
    Oct 2003
    veneta Or
    217
    hydraulic winch
    has anyone try-ed an hydraulic winch? I need one for one of my well drills.to pull the tower up.
    jerry
    Jan 2003
    s.e. minnesota
    1,348
    I have one off of an old well pulling rig that used to be on a 1ton dodge chasis, the tubing in the tower was all rusting/spliting, I think the winch is about the only part I saved. I think it's a smeal, I think that's what it says on it.
    parting several FSJ'S
    A buddy has a Mile-marker hyd on his truck. When driven from the PS pump, it was so slow it was unbearable. He added a separate hydraulic pump and reservoir, and it is at least livable.
    We all had a good laugh a couple of years ago when he drown his engine in a deep water hole. The "let's see you winch yourself out now" thing.
    The good thing is they can run all day without overheating or wearing down the battery. Draw is only about 2 amps for a solenoid. Fluid does heat up, but with a few gallon reservoir it's managable.
    Oct 2003
    veneta Or
    217
    I been . looking at mile-marker and warn. we put in a gage on the line and it takes 3500 Lb. to left the tower.
    jerry
    Aug 2006
    Pittsburgh
    134
    something for lifting a tower shouldnt be a problem with hydraulic. The issue with on something like a jeep is if you stall/ breakdown you cant winch. Yea with an electric you will drain the battery pretty fast doin that but can still get yourself out. But on a drilling rig i wouldnt think you would have that issue.
