Well I finally got all the parts to mount my 401 in the cJ7 frame. I had purchased a used bell housing which came with a fork and spring. I bought a new pivot bearing and internal spring. Put everything together, t150 bellhousing to 401 and mounted in the frame. I tried the clutch after I was done and no engage. Is there different forks available that are different from the 6 cyl to the v8? I have about an inch of play and run out of room before the bearing even touches the clutch. Everything went together good. Maybe the fork is mangled?
Any help will be appreciated as I did not have the original parts with this jeep so I have no idea what they should look like.
