Drill & tap 69 block head bolts to 1/2 inch?
Results 1 to 3 of 3
Thread: Drill & tap 69 block head bolts to 1/2 inch?
    Thank you from BT Ultra tech
    Jan 2004
    Michiana
    457
    Anybody ever do this? How hard is it/what would a machine shop charge?
    I want to go turbo with a '69 390 but the 7/16" bolts are a bit on the small side.
    Thanx in advance!!!
    Nostalgia ProStock.
    Yes, their is enough meat left to do this. What the charge would be I do not know
    Oct 2004
    106
    I did it a long time ago it was a pain but it worked probably not worth paying a shop to do it but that is going to be your $$$
