Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: 304 How much Horsepower?
  1. #11
    Use this formula to calculate HP.
    Torque * RPM
    ------------ = Horsepower
    5252
    So with the graph figure torque=270 @ 3000 RPM
    270*3000/5252 = 154.23 HP @ 3000
    215*5000/5252 = 204.69 HP @ 5000
  2. #12
    Oct 2006
    Virginia
    771
    Figure,... a stock 304 from the factory pushes 125-155hp.... Changing the bore size +.030, with a decent lift cam, intake, Carb, exhaust... with stock heads, even with "minor work"... Getting an added 150hp is a decent task. But, with a little money mainly for the High Compression pistons and a smaller chambered head with decent valves to keep the flow up it'll push decent number mid 3's.... maybe more depending on the set-up.
    But then again here I am preaching to the choir... and probably to people that know more about AMC performance than I can even imagine.
    I'm still sticking with my numbers (250-265 max)
