My Custom Built Trac/Torque Bar
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: My Custom Built Trac/Torque Bar
    Oct 2006
    Virginia
    771
    This is a pic of the Torque Bar that I made for the Jeep... Don't bust on me too hard about the internal bracing... I know I should've angled/trianglated them...
    All together this probably took about 3 to 3 1/2" hours to make... The milling went fast, (The set-up/break down took the longest)... The Chop-saw cut straight and fast... the welding probably took the second longest...
    Let me know you people think..
    Materials Used:
    1 5/8" O.D. x 1/4" thick walled Tubing
    1" O.D. x Either .187" or .200" thick walled tubing
    1/4" Plate Steel
    1/8" Plate Steel
    7018 Welding Rods
    Thats looks awesome!!
    Oct 2006
    Virginia
    771
    Thanks man!!! It's heavy as a Bitch too... It should be able to take some serious punishment... I guess I'll find out when I slam a few Rocks off of it!!!
    Quote Originally Posted by fifesjeep
    Specs?? As in numbers ... I'll need something for the 360+ in the CJ with 44's and a 4.56 locker
    Oct 2006
    Virginia
    771
    Materials Used:
    1.680" O.D. x 1/4" thick walled Tubing
    1.050" O.D. x Either .187" or .200" thick walled tubing
    1/4" Plate Steel
    1/8" Plate Steel
    7018 Welding Rods
    Grabber Green Paint
    The Length On the Large Diameter tubing is as follows:
    Top = 35 1/2"
    Bottom = 36 1/2"
    *At the end where the two larger tubes meet I cut the top of the bottom tube to where the Top tube would fit snugly into the bottom tube... Then I welded them together using 7018 Rods at 90-110amps (making sure I had decent penetration)... After both sides were welded I welded on 1/8" plates to both sides. (I would've used 1/4" but didn't feel like Cutting small pieces out of a large sheet).
    On the ends of the tubing I milled a notch to fit the 1.680" tubing... I Went about half-way or half the thickness of the tubing!
    The inside material "Supports" are as follows:
    1st Support = 1 1/2"
    2nd Support = 2 1/2"
    3rd support = 3 1/2"
    *Notch the tops of the "supports" to match the radius of the larger diameter tubing... Once matched, set inside and light tap the "Supports" until they're Snug and then tacked on opposite sides and then ran the beads.
    The 1/4" Plates that get welded to the axle tube Didn't take much time... I measured my axle OD and then cut the plate steel a little bigger to allow it fit freely... Not snug....
    The only problem that I honestly have with this is the ID of the tubing. I haven't found bushings that will just "Fit"... I had to take my older leaf pack that I had laying around and snag the larger bushings out of them... Then I had to bring the bushings to the shop and turn them down to fit... (I had to cut-up brand new BDS Bushings down to 1.200")... No biggie though, it's for a greater cause... Plus the BDS blue matches the Summit Stickers (Blue)... Well, maybe the BDS bushings are a little lighter if you start looking...
    Anyway, there are my specs...
    As for the fit on the Jeep... "Tight"... with these lengths etc.. the end that will be shackled will be next to the tranny... above and a little infront of the crossmember.. allowing travel/pivot etc... Hopefully those of you who are looking for a decently cheap do it yourself can use this info.
    Re: My Custom Built Trac/Torque Bar
    Well sounds like you have a shop available to "mill" and "turn" in. Since starting this new contract, I don't any more - beside some genius decided to "fix" the auto feed on the mill and now it doesn't work, or even have a handle
    That's why they are also called "Ladder Bars"
    Oct 2006
    Virginia
    771
    What's wrong with the auto feed... Which feed... X, Y or Z? Are you missing the plastic/brass gears?... A handle is easy to make... (where are you located at?)
    Y axis feed assembly was dissassembled by "Somebody" and lost some parts. Which ones I don't know - I just got the blame. I have a suspicion though - the same guy I caught trying to use an end mill as a drill bit, 'Cause it was the exact size ...'
    Funny 'cause, it happened over a weekend, and I was in St. Louis (with an alibi on top of that!!), and why in the hell would I dismember a mill feed???
    I live near Ft. Eustis, the office is in Norfolk, and right now I'm working in Chesapeake (BAE Shipyard).
    Where are you at?
    Oct 2006
    Virginia
    771
    "I have a suspicion though - the same guy I caught trying to use an end mill as a drill bit, 'Cause it was the exact size"
    That's too funny... Plunging in with a 2,3 or 4 flute is alright if it's already pilot drilled... We have a few here in Norfolk that do that.... (Without the pilot hole)... Then when the hole is oversized or fugly looking... or they break the End-Mill they wonder why.... Dumb asses!!!
    "why in the hell would I dismember a mill feed???"
    You never know man, Various reasons... We had a couple $h!t themselves so we had to rob Peter to Pay Paul, (Basically). The last millwright left our shop not too long ago and I got his job added o mine because I was Mechanically Inclined so to speak... No biggie, I already fixed a bridgeport.. ball bearing lead screws etc, gibs... Lodge Shipley lathe, rapid traverse... gears... etc... Simple work once you crack them open... Only I have a problem with making the replacements parts A LOT STRONGER ....
    [/b]
