New distributor gears
I have a used 360 with a prestolite ignition. I would like to put a motorcraft in it because my jeep has a motorcraft ignition any problems with dizzy/cam gear mateing up? I saw somewhere about diz O ring or gasket to adjust the gear height. Would it be better to just get a new set of gears from bulltear? Thanks Lan
Thank you from BT
Tech Master Bulltear Forum
the old gear might not mesh with the gear on the dizzy properly kind of like mixing axle gears, they kind of wear into each other and seat. I would get a new set of gears just to be safe, it'll also give you a chance to check your timing chain
Could I just use the gear from the dist. I took out ?
Thank you from BT
that would probably be fine as long as both are in good shape
- You may not post replies
- You may not edit your posts
Forum Rules
