Results 1 to 8 of 8
Thread: Exhaust Spewage
    May 2005
    Delphos, OH
    40
    Exhaust Spewage
    So who can tell me what's causing this jet black crap to spew out of my exhaust? I get a little bit when I first start up the engine when cold, then as it warms up it is replaced with the usual moisture evacuation caused by condensation as the exhaust heats up. Once warmed up though it starts spewing this black crap out again. Needless to say, I'm continually getting reamed over this as the lower rear quarter on my better half's car keeps getting a fresh goat of exhaust spew.
    My best guess is that it's worn valve seals letting some oil down into the cylinders, but I imagine it could be worn rings causing the same thing. Planned to have the heads reconditioned this winter, but if new rings are needed I'll put the heads off for a bit and do a full rebuild.
    Jim Baker
    1978 Cherokee 360
    Air-Gap Intake/#1405 600cfm Carb
    TH400 Tranny
    QT T-case
    Sep 2006
    Stamford, CT.
    125
    How bout carb running rich or choke not pulling off all the way?
    If it's sooty black I say carb.
    My .02
    Dave ----
    75 GremlinX v8 64k
    76 GremlinX i6 (15yr sons)
    70 Javelin MD 390/4sp (360 now)
    70 Javelin 1/4 Drag car 360/auto best time 12.88...best speed 103.64 mph...best 60' 1.835 no tuning
    Jun 2004
    Central City, Colorado
    1,626
    Yea that would be my guess as well.. the sooty black crap mixes with the condensates and presto sticky black goo..I am guessing you may be running a bit rich. (the first little blast on a cold start is normal and will pretty much always be there.)
    Dirty Harry.
    May 2005
    Delphos, OH
    40
    Highly possible it's the carb as I'm still tweeking the jetting and metering rods trying to get it just right. Engine runs good and smooth with no bogging anywhere to indicate being overly rich, but you can smell it in the exhaust. Will be ordering a HEI dizzy in a week or two as the ignition is all stock at present and probably pretty weak given it's age, so hopefully that extra fire will help things out a bit and make the carb tuning easier.
    Jim Baker
    1978 Cherokee 360
    TH400 Tranny
    QT T-case
    Jun 2006
    942
    Could try pulling the coil wire off of the distrbutoer cap, putting near metal, crank engine, and check for blue white hot sparks that snap. If the spark is kinda orange-ish then coil is weak. Mine was difficult to start, had orange-ish spark, changed coil, and it started very easily. Also had some of the black exhaust discharge. Wondered if it was just the condensate in the pipes washing out some of the carbon. Could just be the car marking it's territory.
    Nov 2005
    Middle of the Iron Range MN
    1,229
    if you can smell that its rich try leaning out the idle circuit. i had a carb that wouldn't respond to idle circuit tuning. turned out that the idle air bleeds were partially plugged and was causing erratic idle problems.
    Jun 2006
    942
    I agree, dirty air bleeds will cause rich problems and poor atomization. Another possibility, if it's an Edelbrock / Carter carb, engine vacuum plays a BIG role in leaning the mixture. The Rods are pulled down into the Main jets by aluminum "pistons" in bores to lean the mixture. These pistons must be clean and free in the bores and are backed up by counterbalnce springs. These springs come in different strengths and can be changed to adjust the leaning point and range based on engine vacuum, especially at idle. The rods, pistons, springs, take the place of power valves on Holleys. Have ya checked your manifold vacuum at idle and messed around with changing out these power enrichment springs ? Engine condition, Spark Timing, Cam, and other factors can reduce vacuum and cause it to go rich or the Rods/Pistons to "bounce" open and closed. Holleys usually use a 6.5" vacuum Power Valve, but in hot rod motors I've often seen cold engine start vaccums around 8.0" or less and have changed out the power valves to 5.5" to prevent them from "leaking" or "bouncing" open and makin' the motors go phat.
    If a Holley has a blown power valve you can usually screw the idle mixture screws all the way in cutting off all idle fuel and the motor'll still run cause it's gettin' gas through the blown power valve diaphram.
    Thank you from BT Ultra tech
    Jan 2004
    Michiana
    457
    I certainly hope your oil is NOT black!!!!
    Here's a way to tell if it's rich or lean. Pull a vacuum line off & see if it revs up or down, if it revs up it's rich, if it revs down it's lean.
    If you have a large cam, you can drill small air bleeds in the primary butterlies to let more air in, if all else fails.
    Sorry for all you guys running Edelbrock (Carter) carbs, but that design is from the 1950s & had run it's course way back when, Carter could sell no more of them. Edelbrock started reproducing them after Carter went belly-up with their obsolete products!!!
    I'll take a Holley anyday over one of those old POSs.
    You couldn't get me to use one by giving me $100 & a brand new one!!!
    Nostalgia ProStock.
