AMc pump gears
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: AMc pump gears
    Apr 2006
    St.C Ohio, 43950
    433
    AMc pump gears
    Ok, on the bottom of the gears theres two dots. What are the importance of these dots? Do you have to align them like timing sets? or does it just mean that it is the bottom of the gears??????
    They are there from the injector pins that push the molted metal into the mold and also vent the air out. No need to clock them.
    Apr 2006
    St.C Ohio, 43950
    433
    Ok.......i just wanted to be sure on this........about another hour or two and this puppy is gettin dropped into the Jeepers. I just want to say thanks everyone for all the info I needed during this build! It's my first AMC and won't be the last either. I have plans already starting for the 360 stroked to a 401 Im gonna run this 304 for a lil while and then start the build on the 401 and then ill be able to show them dumasses what AMC is all about!
    Here Here
    Thank you from BT Ultra tech
    Oct 2006
    KEARNY, NEW JERSEY
    428
    bulltear timing cover
    I bought a Bulltear NI coated timing cover a year or so ago and I was wondering what I need to do to convert to the new style gears. I hear you can't just drop them in. Do I send the cover back to them for fitting?
    No we will need your idler gear for machining and $20
    Oct 2006
    KEARNY, NEW JERSEY
    428
    front cover
    So I should pack up the cover stuff a $20.00 in box plus return postage and send it back to you?
    I have a bunch of old front covers, do you use them as cores or do you only start with new ones?
    I took a couple of 360's and 401's apart and the covers look decent. Are they always a throw away, neaning a new cover should always be used?
    No need for al lthat Joe just the idler gear (The gear without the long shaft). No need for a return box.
    Do the new BT HRC Oil Gears need anything done to them when installing into an old timing cover?
    1959 AMC Rambler Wagon Project
    1968 AMC Jeep Gladiator J3000 327, SOA
    1978 J10 401/th400/qtrack/d44 3.54 SUA Project
    1990 Toyota Celica ST w/ 97 7AFE 1.8 swap
    No prepping is neccesary
